Whiteline Flatout artikelen GOLF MK5 1K GTI & R32 FWD/AWD
Fine Line Imports
Type auto: Subaru Impreza
Bericht door Fine Line Imports »
KCA316 - Anti-lift/caster kit - control arm lower rear
Adviesprijs: € 214,20
Fine Line Imports Prijs: € 197,99
NOTES: IMPORTANT
Adds +0.5º caster + anti-lift - TUV certified
PRODUCT BENEFITS
Whiteline Anti Lift Kit (WALK) is designed to add 0.5 deg static positive caster to both front wheels while changing the nature of front anti-dive & lift. The low compliance bush also maintain higher dynamic positive castor. By changing the front control arm geometry - the new alloy mounts coupled with the new low compliance polyurethane bushes change front suspension attitude. This leads to superior traction under power including cornering & dramatically reducing understeer & front wheel spin. The additional castor coupled with the new firmer bushes supplied serve to dramatically sharpen initial turn-in response then forcing more consistent alignment angles through the corner due to the reduced bush compliance
Dit Artikel is geschikt voor de volgende VW modellen:
Volkswagen BEETLE MK5(2011-ON)
Volkswagen BORA MK5 1K(2/06-ON)
Volkswagen CADDY MK4 2K VAN(2003-ON)
Volkswagen EOS MK1 1F(2006-ON)
Volkswagen GOLF MK5 1K, 1KP INCL PLUS, GTI FWD(8/03/2009)
Volkswagen GOLF R32 MK5 1K, 1KP AWD(8/03/2009)
Volkswagen GOLF MK6 5K INCL GTI FWD(2009-ON)
Volkswagen GOLF R MK6 5K AWD(2009-ON)
Volkswagen JETTA MK5 1K(2/06-5/10)
Volkswagen JETTA MK6 NCS(6/10-ON)
Volkswagen SAGITAR MK5 1K(2/06-5/10)
Volkswagen RABBIT MK5 1K INCL GTI(8/03/2009)
Volkswagen SCIROCCO MK3 13(2008-ON)
Volkswagen TIGUAN 5NC FWD(5/08-ON)
Volkswagen TIGUAN 5NC AWD(5/08-ON)
Volkswagen TOURAN MK5 1T(2003-06)
Volkswagen VENTO MK5 1K(2/06-ON)
Volkswagen VENTO MK6 NCS(6/10-ON)
Instalatie guide vind je hier: http://whiteline.com.au/docs/install_gu ... _Z5508.pdf
Complete catalogus staat online en is simpel te navigeren via onze wizard:
http://www.fineline-imports.nl/whitelin ... ion/c8956/
Website: https://www.fineline-imports.nl
Facebook: https://www.facebook.com/FineLineImportsnl/
email: info@fineline-imports.nl
Wij zijn van 09.00 tot 15.00 te bereiken op 036-8447700 of 06-24666645
leverancier van o.a. Ferodo, Brembo, DBA, Whiteline, GFB, Hawk, Invidia, Supersprint, Xforce, Turbosmart, ACL en nog veel meer ;)
Terug naar “Fine Line Imports”
