Vandaag nog is even de Vagcom aan men mk5 gehangen en er kwampen toch een paar foutjes op.
Kan iemand vertellen wat de fouten juist zijn? en of ik me zorgen moet maken?
ddress 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 A HW: 1K0 907 115 A
Component: 2.0l R4/4V TFSI G00 0070
Revision: --H01--- Serial number: VWZ7Z0E1508958
Coding: 040300031C070160
Shop #: WSC 01279 785 00200
VCID: 244DF249E7C0DE9
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
ddress 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CDDDA694F90D69
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001437744
Coding: E78F8F0600041818001400001400000000087F075C
Shop #: WSC 12345 123 12345
VCID: 3A712C317544B89
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 050706 020 0501
Coding: 00038805
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 12345
1 Fault Found:
02395 - Parking Light Right Front (M3)
012 - Electrical Fault in Circuit - Intermittent
dress 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No SW: 1K0 959 433 H HW: 1K0 959 433 H
Component: 01 KSG PQ35 G2 012 0308
Revision: 00012000 Serial number: 00000000000000
Coding: 81C802087F2D8D0D484AC6F000
Shop #: WSC 02453 202 81977
VCID: 356B3F0D5C5A571
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0002
Coding: 0000003
VCID: F4ED420997A08E9
1 Fault Found:
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
010 - Open or Short to Plus
Alvast bedankt
Paar foutmeldingen, beetje hulp?
Re: Paar foutmeldingen, beetje hulp?
Kijk even op Gerrit speek zijn website.
Staan (bijna) alle foutcodes beschreven, maar lijkt erbij eerste instantie op dat een aantal fouten zijn veroorzaakt door een (bijna) lege accu.
Ok, alvast bedankt.
- NL_MK5 GTI
- Type auto: MK5 GTI DSG
Ja inderdaad je accu even doormeten ook even je dynamo. Je dynamo kun je het beste doormeten met de polen van de accu af als je auto stationair draait uiteraard. Als er en cel kapot is in de accu geeft hij niet de juiste spanning door op je multimeter. (spreek uit ervaring wou al bijna me dynamo vervangen)
