GFB Electronische boostcontroller
Fine Line Imports
Type auto: Subaru Impreza
Bericht door Fine Line Imports » 19 feb 2013, 16:42
The G-Force II Electronic Boost controller may be high tech but it's not about extra dial and buttons, its about performance! The G-Force is easy to fit, fast to tune and set up and with a functional user interface it's just easy to use
Real-time boost gauge; display in bar, psi, or kPa
Choose the gauge display pressure units to suit your preference
Real-time vacuum display
Now shows manifold vacuum as well as boost
Over-boost warning/cut
User adjustable warning to indicate if the boost pressure is too high and to cut the solenoid to lower boost and protect the engine
Youtube Filmpje: http://www.youtube.com/watch?v=qtkzGu-iHCQ
Nu uit voorraad leverbaar voor €275,00
Directe bestellink: http://www.fineline-imports.nl/gfb-go-f ... 14056.html
email: info@fineline-imports.nl
Wij zijn van 12.00 tot 19.00 te bereiken op 036-8447700 of 06-24666645
leverancier van o.a. Ferodo, Brembo, DBA, Whiteline, Apexi, GFB, Exedy, Hawk, Invidia, Tarox, Supersprint, NGK en nog veel meer ;)
Terug naar “Fine Line Imports”
