Golf VII (hoe betrouwbaar is dit)
Golf VII
Autoweek berichtte hierover. Maar hoe betrouwbaar is dit?
http://www.autoweek.nl/autonieuws/17075 ... vii-zweten
Re: Golf VII (hoe betrouwbaar is dit)
Ik zie geen verschil met de 6 ???
- NICO!
- Forumeigenaar
- Type auto: BMW iX3
Dat noemen ze geloof ik een "mule", ze gebruiken de body van de 6 over de nieuwe onderkant van de 7 om maar niets van de looks prijs te geven. Je ziet bijvoorbeeld dat de achterspatborden niet passen en dat er extra stukken op gezet zijn. Je mag er dus vanuit gaan dat de achterkant van de 7 iets breder zal zijn.
The new instrument panel features a large speedometer and rev counter, which also house the fuel and engine temperature gauges in 360-degree readouts. Fuel and temperature levels will be displayed through a string of LED lights, continuing the circular theme. This design frees space for a large trip computer screen between the two main dials.
This instrument panel should be shared between the upcoming seventh generation Golf hatchback, estate, cabrio and Golf Plus.
Although hidden under bodywork from the current car, the blistered and wider wheel-arches are a clear indication that the test mule is running the next generation Golf’s underpinnings.
More specifically, the Mk7 will be built on the VW Group’s more space-efficient and, according to sources, substantially lighter, MQB platform that comes with a longer wheelbase and shorter overhangs. First seen on the new Sharan minivan, the flexible MQB platform will be used on a raft of VW Group models including the next Audi A3, which is expected to be revealed either in late 2011 or early 2012.
Volkswagen Group MQB platform: http://en.wikipedia.org/wiki/Volkswagen ... B_platform
Lijkt wel een quartet set van vroeger
GOLF VI GTI ABT
---18'' Detroits---
GOLF VII 2.0 TDI
---18" Durban----
---18'' Detroits---
GOLF VII 2.0 TDI
---18" Durban----
Tooling for the new Golf 7 is already underway in Wolfsburg. We expect to see the Golf 7 introduced in the fall of next year (2012) most likely at the Paris Motor Show. The GTI would likely follow a few months later. The German press has been reporting that 2.0T in the new GTI will get a version boosted to 230-240hp. Base engines for the U.S. market are likely to be a new 1.8T FSI and 2.0 TDI but that is subject to change. We'll keep you posted if we hear more.
maandag op de terug weg uit Italië bij Augsburg kwam ik een GTI VI tegen die er precies zo uit zag als de auto van de begin post. In de file wat aandachtiger kunnen kijken naar de auto. Alleen voor zaten er stoelen. de auto stond op 16 inch velgen en overal waar je keek in die auto zaten computers.
wat zijn de voor remschijven groot....
en links en rechts dubbele uitlaten...
zal ze de uitlaat van de 7 gti worden? wie weet
Gebruikers op dit forum: Geen geregistreerde gebruikers en 91 gasten
