*GADGET* Torque Pro
*GADGET* Torque Pro
Heb wel een erg leuke Gadget gevonden,
Alleen ben nog een Nederlandse verkoper aan het zoeken
See what your car is doing in realtime, get OBD fault codes, car performance, sensor data and more!
Torque is a vehicle / car performance / diagnostics tool that uses an OBD II Bluetooth adapter to connect to your OBD2 engine management / ECU
Layout your own dashboard with the widgets / gauges you want!
It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
It can also show and reset a DTC / CEL / fault code like a scantool. Helps you fix your car and helps keep repair costs down!
Torque also features:
* Dyno / Dynomometer and Horsepower/HP & Torque
* Can read Transmission Temperatures (vehicle dependant)
* 0-60 speed timings - more accurate than just using plain old GPS - see how fast your car is (or truck )
* CO2 emissions readout
* Customisable dashboard & profiles
* Video your journey using the Track Recorder plugin with onscreen OBDII data overlay - a black box for your car/truck!
* Automatically send GPS tagged tweets directly to twitter (for example if you are going on a road trip)
* Massive fault code database for allowing lookup of fault codes from different manufacturers
* Theme support (choose from different themes to change the look of your dashboard)
* Send logging information to web or email CSV/KML for analysis via excel / openoffice
* Heads up display / HUD mode for night time driving
* Compass (GPS Based) that won't suffer magnetic interference
* GPS Speedometer/Tracking and realtime web upload capability - see what you were doing and your engine, at a point in time
* Turbo boost feature for vehicles that support MAP and MAF sensors (VW & Golf / Audi / Seat etc supported)
* Alarms and warnings (for example if your coolant temperature goes over 120C whilst driving) with voice/speech overlay
* Car dock support
* Graph data
* Able to share screenshots to Facebook, Twitter, Google+, Email, etc
* AIDL API for connecting third party apps, A simple Telnet interface for developers to talk to the adapter, and an OBD scanner.
* Works on tablet devices like the Motorola Xoom, Dell Streak, and Samsung Galaxy Tab
* Car dock support
* Graph data
Re: *GADGET* Torque Pro
Die bluetooth dongle kan je voor weinig bestellen op ebay. ik heb er ook eentje komt werkte erg goed op mijn Ibiza cupra. heb het nog niet getest op de GTI
Ben benieuwt hoe deze werkt op je Gti
Alleen voor Android, (nog) niet voor Iphone.
Verkoop alleen via Ebay???
link: http://torque-bhp.com/
- Type auto: Gti v 30edition
Grrrr.... Niet voor iphone
Wel een hele gave gadget!
Zou je het niet werkent kunnen maken met je rns 510?
Dat zou helemaal VET zijn!
- Spuugemmer
- Type auto: MK1 GTI
PLX kiwi is er voor de ifohn!! Heb ik eens een keertje gekocht en doet het best leuk. Ben wel van mening je gebruikt het 3x en daarna zelden. Hooguit om een storing te wissen op vakantie oid...
Golf MK1 GTI
Hmmm niet echt een vervanging van analoogmeters dus:(
Als k hem zou kopen dan is het ook meer vOor de storingen haha
- Spuugemmer
Ik ben er door zelf proberen achtergekomen dat het toch wel belangrijk is dat meters in je gezichtsveld zitten en niet naar beneden. Doorgaans heb je meters alleen nodig als je full pull bezig bent..Dan is voor je kijken ook wel prettig! Maar het is zeker een leuk tooltje
Golf MK1 GTI
Chris@XT Motorsport schreef:PLX kiwi is er voor de ifohn!! Heb ik eens een keertje gekocht en doet het best leuk. Ben wel van mening je gebruikt het 3x en daarna zelden. Hooguit om een storing te wissen op vakantie oid...
Om even door te gaan op deze PLX kiwi (wifi uitvoering). Volgens de specs. kan die ook de turbodruk weergeven, zonder toevoeging van optionele sensor-modules. Dit in combinatie met bijv. de app.: Dashcommand.
Vraag, als je hem hebt geprobeerd, doet ie dat ook?
(in dit specifieke geval van een GTI V of VI waar de turbodruk niet direct op de CANBUS aanwezig is.)
link:
http://www.plxkiwi.com/kiwiwifi/hardware.html
http://www.plxkiwi.com/kiwiwifi/software.html
- Spuugemmer
Ja hij geeft turbodruk weer is dan alleen wel weer auto afhankelijk. Hij doet het niet bij alle mk5jes.
Golf MK1 GTI
Ja.. bij de TSI motoren en TDI's ligt de turbodruk "vrij". Maar bij de GTI's niet. Of wil je zeggen dat er exemplarisch GTI's (bouwjaar-, type motor, - type ECU afhankelijk) dit wel kunnen? Dat maakt de zaak ineens veel interessanter.Chris@XT Motorsport schreef:Ja hij geeft turbodruk weer is dan alleen wel weer auto afhankelijk. Hij doet het niet bij alle mk5jes.
Hmmmm wordt dit toch weer intresant.. Turbo druk via deze app.
Bkijf deze ff volgen.
Het volgende wordt getest op het Duitse GTI forum:
Een van de volgende Wifi OBDII adapters:
http://www.ebay.de/itm/WLAN-Wifi-Automo ... 3cbcb57bca
In combinatie met de volgende Iphone app: REV.
http://www.devtoaster.com/products/rev/
Turbodruk wordt weergegeven.
In combinatie met Dashcommand:
http://itunes.apple.com/nl/app/dashcomm ... 93183?mt=8
VET!!!!!!!!
Ik heb van dit software zelf geen kaas gegeten.. Zou wel cool zijn als je dit ook werkend kan maken op de rns510 scherm?!
- Dumdum_Edition30
- Type auto: Golf 7R
Heb deze gekocht om olietemperatuur af te lezen. Maar kan dat nu wel niet aflezen zeker van de ECU.
Gebruikers op dit forum: Geen geregistreerde gebruikers en 127 gasten
