Catch Can TSI motor
Geplaatst: 27 jun 2012, 21:03
Voor de TSI rijders onder ons heb ik wat informatie gezocht over een Catch Can die wel op hun motor past en geen €450,- kost zoals die van Forge.
Price: $289.99
FedEx (International Priority) $61.53
Totaal: $ 351,52 (€ 281,71)
http://www.bshspeedshop.com/bshstore/pr ... -Can-.html
By adding a BSH Competition Catch Can system to your 2.0T TSI you are protecting your stock or tuned motor from the drawbacks of allowing blowby gasses to enter your combustion chamber. As the TSI engine is both high compression and turbocharged, allowing volatile oil vapor access will reduce power across the rev range by making the engine substantially more prone to pre-ignition/detonation. Keep your timing up and a smile on your face by getting those gasses out of your engine!
Includes:
BSH Competition High Capacity Catch Can
BSH Billet PCV Adapters
BSH Billet Manifold Cap
BSH Billet Dip Stick
Laser Cut Catch Can Bracket
Integrated O-Ring Sealed Drain
Oil and Heat Resistant O-Rings
Retaining Hardware
Push Lock Hose
Notes:
Installed in under one hour
Compatible with BSH Boost Tap
A Complete PCV Fix
Fully compatible with stock engine cover
How to install:
http://forums.vwvortex.com/showthread.p ... =bsh+catch
http://www.namotorsports.net/docs/BHBSHTSIRECC.pdf
after 5 days...
And this is after 5 months of collecting
Price: $289.99
Includes:
Retaining Hardware
Push Lock Hose
Notes:
A Complete PCV Fix
How to install:
after 5 days...
