[V]Waar zijn alle zekeringen voor
Dirk
Bericht door Dirk »
These are the fuse assignments for 'Fuse Panel C' located at the left side of the dash:
1 -SC1 -Fuse 1 (on fuse panel C)10A -J485-Auxiliary Heater Operation Relay N79-Positive Crankcase Ventilation (PCV)Heating Element (BUB,BMJ,BWA) G70-Mass Air Flow (MAF)Sensor (AXX,BWA,BPY) J757-Engine Component Power Supply Relay T16-Data Link Connector (DLC) (T16/1)J431-Headlamp Range Control Module
15a
2 -SC2 -Fuse 2 (on fuse panel C)10A -J623-Engine Control Module (ECM) E1-Light Switch V49-Right Headlamp Beam Adjustment Motor V48-Left Headlamp Beam Adjustment Motor E102-Headlamp Beam Adjustment Motor J538-Fuel Pump (FP) Control Module (AXX,BWA,BPY)J492-All-Wheel Drive Control Module J345- Towing Recognition Control Module J587-Selector Lever Sensor System Control Module J533-Data Bus On Board Diagnostic Interface J285-Instrument Cluster Control Module J500-Power Steering Control Module J104-ABS/EDL Control Module E132-Anti-Slip Control Switch E256-ASR/ESP Button G100-Brake Pedal Position Sensor,(from November 2005)
15a
3 -SC3 -Fuse 3 (on fuse panel C)5A -J234 -Airbag Control Module 15a
4 -SC4 -Fuse 4 (on fuse panel C)10A -G266-Oil Level Thermal Sensor M17-Backup Lamps J255-Climatronic Control Module G65-High Pressure Sensor E16-Heater/Heat Output Switch J530-Garage Door Opener Control Module N253-Battery Interrupt Igniter Y7-Automatic Day/Night Interior Mirror E422-Tire Pressure Monitoring Display Button K216-ASR/ESP Control Lamp 2 Z20-Left Washer Nozzle Heater Z21-Right Washer Nozzle Heater
15a
5 -SC5 - Fuse 5 (on fuse panel C) 5A -J745-Headlamp Range/Cornering Lamp Control Module,on right headlamp 15a
6 -SC6 - Fuse 6 (on fuse panel C)5A -J745-Headlamp Range/Cornering Lamp Control Module,on left headlamp 15a
7 -SC7 - Fuse 7 (on fuse panel C)5A --Not used 15a
8 -SC8 - Fuse 8 (on fuse panel C)10A --Not used 15a
9 -SC9 - Fuse 9 (on fuse panel C) ---Not used 15a
10 -SC10 - Fuse 10 (on fuse panel C)---Not used 15a
11 -SC11 - Fuse 11 (on fuse panel C)---Not used 15a
12 -SC12 - Fuse 12 (on fuse panel C)10A -J386-Driver ’s Door Control Module (window regulator) J387-Front Passenger ’s Door Control Module (window regulator)30a
13 -SC13 - Fuse 13 (on fuse panel C)10A -T16-Data Link Connector (T16/16) E1-Light Switch G397-Rain/Light Recognition Sensor G197-Compass
30a
14 -SC12 -Fuse 12 (on fuse panel)10A -F -Brake Light Switch J217-Transmission Control Module (TCM) J587-Selector Lever Sensor System Control Module R149-Auxiliary Engine Coolant Heating RF Receiver E16 -Heater/Heat Output Switch J301-A/C Control Module J255-Climatronic Control Module J446-Parking Aid Control Module J104-ABS/EDL Control Module
30a
15 -SC15 -Fuse 15 (on fuse panel)7.5A -J519-Vehicle Electrical System Control Module (interior illumination)30a
16 -SC16 -Fuse 16 (on fuse panel)---Not used 30a
17 -SC17 -Fuse 17 (on fuse panel)5A -G273-Interior Monitoring Sensor G384-Vehicle Inclination Sensor H12-Alarm Horn
30a
18 -SC18 -Fuse 18 (on fuse panel)5A --Not used 30a
19 -SC19 -Fuse 19 (on fuse panel)5A -J754-Crash Data Recorder 30a
20 -SC20 -Fuse 20 (on fuse panel)5A --Not used 30a
21 -SC21 -Fuse 21 (on fuse panel)---Not used 30a
22 -SC22 -Fuse 22 (on fuse panel)40A -V2 -Fresh Air Blower (Climatronic)30a
22 -SC22 -Fuse 22 (on fuse panel)40A -V2 -Fresh Air Blower (Climatronic),rear battery 29a
23 -SC23 -Fuse 23 (on fuse panel)30A -J386-Driver ’s Door Control Module (window regulator) J387-Front Passenger ’s Door Control Module (window regulator)30a
23 -SC23 -Fuse 23 (on fuse panel)30A -J386-Driver ’s Door Control Module (window regulator),rear battery J387-Front Passenger ’s Door Control Module (window regulator),rear battery 29a
No.Designation in Current Flow Diagram Nomina l Value Function/Component Terminal
24 -SC22 -Fuse 22 (on fuse panel)25A -J388-Left Rear Door Control Module (Central Locking) J389-Right Rear Door Control Module (Central Locking) J393-Comfort System Central Control Module
30a
25 -SC25 -Fuse 25 (on fuse panel)25A -Z1 -Heated Rear Window J301-A/C Control Module (only with additional water heater) E16-Heater/Heat Output Switch (only with additional water heater) N24-Fresh Air Blower Series Resistor (only with additional water heater)
30a
25 -SC25 -Fuse 25 (on fuse panel)25A -Z1 -Heated Rear Window,rear battery J301-A/C Control Module (only with additional water heater) E16-Heater/Heat Output Switch (only with additional water heater),rear battery N24-Fresh Air Blower Series Resistor (only with additional water heater),rear battery
29a
26 -SC26 -Fuse 26 (on fuse panel)30A -J388-Left Rear Door Control Module (window regulator) J389-Right Rear Door Control Module (window regulator)30a
26 -SC26 -Fuse 26 (on fuse panel)30A -J388-Left Rear Door Control Module (window regulator),rear battery J389-Right Rear Door Control Module (window regulator),rear battery 29a
27 -SC27 -Fuse 27 (on fuse panel)15A -J538-Fuel Pump (FP)Control Module G6-Transfer Fuel Pump (FP)30a
27 -SC27 -Fuse 27 (on fuse panel)15A -J538-Fuel Pump (FP)Control Module,rear battery G6-Transfer Fuel Pump,rear battery (FP)30a
28 -SC28 -Fuse 28 (on fuse panel)25A -Special Purpose Vehicle Socket (Not for USA/Canada)30a
29 -SC29 -Fuse 29 (on fuse panel)10A --Not used 15a
30 -SC30 -Fuse 30 (on fuse panel)20A -J217 -Transmission Control Module (TCM) J743-Direct Shift Gearbox (DSG)Mechatronic Terminal 15a
31 -SC31 -Fuse 31 (on fuse panel)20A -V192 -Brake System Vacuum Pump 15a
29a
28 -SC28 -Fuse 28 (on fuse panel)25A -Special Purpose Vehicle Socket 30a
30 -SC30 -Fuse 30 (on fuse panel)20A -J217 -Transmission Control Module (TCM) J743-Direct Shift Gearbox (DSG)Mechatronic 15a
32 -SC32 -Fuse 32 (on fuse panel)30A -U13 -Converter with Socket,12V,230V-110V 29a
33 -SC33 -Fuse 33 (on fuse panel)25A -J245-Power Sunroof Control Module 29a
34 -SC34 -Fuse 34 (on fuse panel)15A -V125-Driver's Seat Lumbar Support Curvature Adjustment Motor V126-Front Passenger ’s Seat Lumbar Support Curvature Adjustment Motor V129-Driver's Seat Lumbar Support Height Adjustment Motor V130-Front passenger Seat Lumbar Support Height Adjustment Motor
29a
35 -SC35 -Fuse 35 (on fuse panel)--Not used 29a
36 -SC36 -Fuse 36 (on fuse panel)20A -V11 -Headlamp Washer Pump J39 -Headlamp Washer Relay 29a
37 -SC37 -Fuse 37 (on fuse panel)30A -J131 -Driver's Heated Seat Control Module J132-Front Passenger ’s Heated Seat Control Module 29a
38 -SC38 -Fuse 38 (on fuse panel)20A -J388-Left Rear Door Control Module (Central Locking System),with J641-Alarm Horn Relay,rear battery J389-Right Rear Door Control Module (Central Locking System),with J641-Alarm Horn Relay,rear battery
30a
39 -SC39 -Fuse 39 (on fuse panel)---Not used 30a
40 -SC40-Fuse 40 (on fuse panel)401A -E16-Heater/Heat Output Switch (fresh air bower) J301-A/C Control Module (fresh air blower)75a
41 -SC41 -Fuse 41 (on fuse panel)20A -V12-Rear Window Wiper Motor J729-Dual Washer Pump Relay 1 J730-Dual Washer Pump Relay 2
75a
42 -SC42 -Fuse 42 (on fuse panel)20A -U1-Cigarette Lighter U9-Rear Cigarette Lighter U5-12 V Socket (criminal investigation)(Not USA/Canada)
75a
43 -SC43 -Fuse 43 (on fuse panel)15A -J345-Towing Recognition Control Module 30a
44 -SC44 -Fuse 44 (on fuse panel)20A -J345-Towing Recognition Control Module (not for rear battery)30a
45 -SC45 -Fuse 45 (on fuse panel)15A -J345-Towing Recognition Control Module 30a
46 -SC46 -Fuse 46 (on fuse panel)---Not used -
47 -SC47 -Fuse 47 (on fuse panel)---Not used -
48 -SC48 -Fuse 48 (on fuse panel)10A --Mag-Lite and portable two-way radio charging station 75a
49 -SC49 -Fuse 49 (on fuse panel)---Not used -
Audi A4 1.8 TFSI
Type auto: BMW i5
Re: Waar zijn alle zekeringen voor
Leuk lijstje, maar kan je in de titel aangeven voor welk type GTI deze lijst is?
Dirk
Re: [V]Waar zijn alle zekeringen voor
Bericht door Dirk »
aangepast :D
Audi A4 1.8 TFSI
