Radio geeft een hoop fouten?
Het lijkt net of dat er een kant niet werkt.
dit gaf de vag com :
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
Component: RNS-MID H11 3890
Revision: AB001001 Serial number: VWZ6Z7L8036052
Coding: 06060400040000120000
Shop #: WSC 00237 211 81319
ASAM Dataset: ------------------------- ------
VCID: 2F6669AD7EC78360891
12 Faults Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 254
Reset counter: 19
Mileage: 141760 km
Time Indication: 0
Date: 2000.00.00
Time: 21:50:51
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 234
Mileage: 141760 km
Time Indication: 0
Date: 2000.00.00
Time: 21:51:00
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:23
00872 - Bass Speaker Rear Left (R15)
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:29
00871 - Bass Speaker Front Right (R23)
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 00:43:27
00870 - Bass Speaker Front Left (R21)
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 00:43:27
00874 - Treble Speaker Front Left (R20)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:13
00876 - Treble Speaker Rear Left (R14)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:14
00875 - Treble Speaker Front Right (R22)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:14
00877 - Treble Speaker Rear Right (R16)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:14
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 234
Mileage: 144166 km
Time Indication: 0
Date: 2000.00.00
Time: 19:21:40
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 234
Mileage: 144166 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:04
Iemand enig idee of dat dit in de instelling zit?
12 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141760 km
Time Indication: 0
Date: 2000.00.00
Time: 21:50:51
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 234
Mileage: 141760 km
Time Indication: 0
Date: 2000.00.00
Time: 21:51:00
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:23
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 16:00:29
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 00:43:27
Freeze Frame:
Fault Priority: 5
Reset counter: 19
Mileage: 141928 km
Time Indication: 0
Date: 2000.00.00
Time: 00:43:27
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:13
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 19
Mileage: 144160 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 234
Mileage: 144166 km
Time Indication: 0
Date: 2000.00.00
Time: 19:21:40
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 234
Mileage: 144166 km
Time Indication: 0
Date: 2000.00.00
Time: 19:28:04
Re: Radio geeft een hoop fouten?
Radio is niet goed gecodeerd.
ik weet niet op welke ik hem moet zetten , want bij vorige auto zat ik al verkeerd....MkVI Nmgn schreef:Radio is niet goed gecodeerd.
De antennefout is waarschijnlijk dat je maar 1 ipv de gewenste 2 antennes hebt. Het geluid is hoogstwaarschijnlijk verkeerde audiosysteem instelling. Aux staat volgens mij aan terwijl je deze niet hebt (of omgekeerd)
De samenvatting was hierboven al gegeven: niet goed gecodeerd
hij was al ze gecodeerd toen ik hem kocht... dus het kan best zijn dan er 1 antenne los achter ligt.Lean schreef:De antennefout is waarschijnlijk dat je maar 1 ipv de gewenste 2 antennes hebt. Het geluid is hoogstwaarschijnlijk verkeerde audiosysteem instelling. Aux staat volgens mij aan terwijl je deze niet hebt (of omgekeerd)
maar ik zit er meer mee dat hij geluid gewoon niet goed is....
Via het (hidden-) setupmenu is de ontvangst van de 2e tuner te zien.
In de eerste foutmeldingsstatus wordt het al aangegeven:
12 Faults Found:
Niet al je fouten zijn op hetzelfde tijdstip ontstaan/vastgelegd in het foutengeheugen.
12 Faults Found:
Iedere auto heeft een eigen codering nodig. Kan zijn dat er een soundsystem (zoals dynaudio) ingeschakeld is welke een versterker verwacht. Als je dit dan niet in je auto hebt dan is er een miscommunicatie tussen radio en speakers. Hierdoor is het mogelijk dat het geluid het niet goed doet.Da Master schreef:hij was al ze gecodeerd toen ik hem kocht... dus het kan best zijn dan er 1 antenne los achter ligt.Lean schreef:De antennefout is waarschijnlijk dat je maar 1 ipv de gewenste 2 antennes hebt. Het geluid is hoogstwaarschijnlijk verkeerde audiosysteem instelling. Aux staat volgens mij aan terwijl je deze niet hebt (of omgekeerd)
Mocht dit met alle instellingen zo zijn dan is er toch iets aan de hardware kant niet goed. Radio/bedrading/speakers.
Even goed coderen en al je fouten zijn weg
Zoals hierboven al aangegeven, heeft elke auto een andere codering nodig.
Of je moet echt toevallig precies dezelfde uitrusting hebben.
De no signal/communication fout krijg je vaak na het in en uitbouwen, dat is een kwestie van wissen
