wot box launch control
Iemand ervaring met een Wot Box / inbouwen en installeren ?
Type auto: BMW i5
Re: wot box launch control
Wat doet het, wat kan je ermee? Wat het ook is, je auto zal er wel van kapot gaan ;-)
Filmpjes zeggen meer als woorden
Laatst gewijzigd door MkVI Nmgn op 26 jul 2011, 12:57, 1 keer totaal gewijzigd.
Volgens wat links die ik zo even snel bekeken heb:
1. "launch controll systeem" = bij volgas wordt een bepaald aantal toeren vast gehouden om zo snel mogenlijk te starten met zo min mogenlijk wielspin...
2. The WOT Box is an electronic device that makes WOT shifting easy by reducing your engine's power for a very short timed period while you shift. It allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. If the input shaft on a manual transmission is not allowed to slow down enough it will lock you out of gear time after time. We have developed a solution to the problem by controlling the ignition at the shift point to ease the transition from one gear to another.
The WOT Box adds two major features to any car. They are No-lift shifting and 2-step launch control. Both of these features are completely user-programmable using the WOT Box Graphical User Interface.
The No-Lift Shift feature makes no-lift shifting easy by cutting your engine's ignition for a very short period while you no-lift shift. No-lift shifting is keeping the gas down through the shifft. The ignition cut allows the synchros in your transmission to mesh easily, reducing the chance of missing a gear and damaging your transmission. Keeping your foot down through the shift also allows you to hold boost through the shift, thereby significantly improving your E.T.
The major benefits are:
* Lower ETs
* Reduced chance of missing a gear
* More consistent, effortless shifts
* Reduced wear on the transmission
* Reduced chance of major transmission damage
The 2-Step Launch Control modulates the ignition by cutting power to individual ignition coils to hold the RPM you want to launch at. The turbo will spool up while you do this. You can use this feature for a more consistent and more powerful launch in boost!
Heb er zelf geen ervaring mee... na het lezen van wat site zou ik denk ik voor een short shifter gaan dan een regelunit...ik denk dat je hier alleen optimaal voordeel met hebt als je meedoet aan dragraces...
heb wel een beschrijving gevonden voor het inbouwen naar een paar uur zoeken :P
http://www.npcompleteperformance.com/vw ... structions
Type auto: Gti v 30edition
Bericht door Mackdennis »
Doet jd dit ook niet bij een chip?
Zorgen dat het vermogen de eerste 2 versnellingen beperkt blijft?
Spuugemmer
Type auto: MK1 GTI
Bericht door Spuugemmer »
Als je dit soort dingen wil had je dan niet beter een Honda kunnen kopen of een dsg?? Zoals je in dat tweede filmpje ziet werkt dat verhaaltje met wielspin verminderen niet echt fantastisch.
heb ik het gehad over dat ik geen wielspin wil. volgens mij niet
maar ik weet dat het een stuk minder word i.p.v. in de toeren begrenzing weg te trekken wat totaal onzin is
Wil gewoon net als launch controle 3000 rpm vast kunnen houden
En wat heeft een honda of dsg hier mee te maken ? als ik 1 van die dingen gewild had had ik waarschijnlijk hier deze vraag niet gesteld
funracer
Bericht door funracer »
Ik vind het gewoon een über toffe gadet
Alleen dat geluid all... Heerlijk!!!
Had al eens gezocht naar zoon anti lag systeem maar nu dus gevonden..
Maar weet niet of het wel gezond is voor de turbo
Anders wil ik er ook eentje
Als je auto gewoon goed warm is kan het weinig kwaad want je turbo druk komt op de helft van wat die aankan
Maar nu komt het volgende waar bestel je het :P
Gevonden http://www.n2mb.com/wotbox
Item total:$199.00
Shipping and handling Shipping and handling (to ) loading...$19.99
Total:$218.99 USD
€151,00
funracer
Tonnie dat weet ik nog zo snel niet hoor
Er komt dan onverbrande benzine bij de turbo en kat meschien is dat wel slegt?
En had al iemand gezien op YouTube die het aansloot op een knopje net zoals de traction control zag er heel netjes uit
Meschien na de zomer dat ik het bestel
http://heijtecshop.nl/wot-box-launch-control.html
Wel stuk duurder dan liever zelf vanuit de vs laten komen
funracer schreef:Tonnie dat weet ik nog zo snel niet hoor
Ik bestel het ook over maandje ofzo pas wil eerst twin take luchtfilter
theo
Global Moderator
Bericht door theo »
Lekkere vage site die uit de usa.
En dan komen de BTW en invoerrechten er nog bij.
funracer
Nee onder de 300€ komt er geen invoerrechten en btw bij
En daarboven ook vaak niet... Alleen als de douane net you paketje gaat controleren
G-sixty
Bericht door G-sixty »
funracer schreef:Nee onder de 300€ komt er geen invoerrechten en btw bij
Vanaf 22,- moet je al BTW betalen en vanaf 150,- komt er ook nog eens douanerechten bij
Bron: http://www.douane.nl/particulier/intern ... en-02.html
Een kennis van me heeft dit ding ook besteld bij die heijtecshop voor zijn golf4 1.8t.
Hij is er wel tevreden over. Hij heeft een sportuitlaat en dat klapt in ieder geval wel aardig
met optrekken en schakelen.
funracer
Hmm ok... Dan ben ik verkeerd geïnformeerd
Heeft die kennis van you het er al lang in zitten ??
En heeft hij een backfire? Op sommige filmpjes is dat wel het geval
G-sixty
Een maandje denk ik.
Er komen aardige klappen en vlammen uit de pijp met schakelen en met launch control al helemaal.
Maar hij heeft wel een sportuitlaat vanaf de downpipe (merk is me niet bekend) dus dat zal wellicht ook wel verschil maken.
Spuugemmer
Type auto: MK1 GTI
tonnie024 schreef:heb ik het gehad over dat ik geen wielspin wil. volgens mij niet
Ten eerste een DSG heeft STANDAARD launchcontrol en wot shift. Honda's uitgerust met een k-pro of k-100/200 ecu hebben deze functie ook erop zitten.
In de toerenbegrenzer weg trekken? het is geen schakelaar je gaspedaal. Maar dan nog je bent niet de enige op het forum en reageerde op het verhaaltje wat verlengsnoer plaatste. Als je met voldoende vermogen rijdt kort in 1 en dan vanuit 2 snelheid gaan maken. max 10 meter is voldoende om klaar te zijn met zijn 1.
Als je inderdaad had gesnapt waar ik op doelde en je had een van de 2 gehad dan had je inderdaad je vraag niet hoeven te stellen.
Let er wel ff op dat je een foutcode kan krijgen op cilinder overslag omdat de software niet helemaal snapt wat er allemaal gebeurd.
BASK04
Bericht door BASK04 »
Good posting
G-sixty
Ik heb hem nu ook besteld bij die Heijtec.com
Ik zal binnenkort de filmpjes plaatsen.
Ben erg benieuwd!
funracer
Enne heb je uhm er al inzitten ??
Gebruikers op dit forum: Semrush [Bot] en 4 gasten
